interfacing andor camera
how I can interface a andor camera (ultra ixon 897) on labview ?.is there a specific module or examples to guide me .
(7,513 Views)
Yes - there are examples for NI Vision (the LabVIEW vision/image processing toolkit) in the example finder.
Do you know if your camera is supported? What sort of connection is it?
Once you have NI Vision installed, see if it appears in MAX and see if you can capture images from it. If you can, then it's supported and you can try it with one of the examples from the example finder.
(blog)
(7,506 Views)
I think he assumed that camera.
commenucation series is a USB 2.
but I like to see,Is there other modules that IMAQ and IMAQdx devloppés for this type of camera.
in my opinion there is at3mod module. it has devloppé for cmos camera .but I will work on an EMCCD camera.
THANK YOU anyway
(7,492 Views)
Hi Dally,
your question is indipendent by the label of the camera. It's important just the kind of communication you have between your device and the PC. Using USB you can download IMAQdx and then you'll find all the examples you need.
Have a nice day!
Bye
(7,438 Views)
hi giu7
I have connected the camera to PC, and although I downloaded the Drivers | of this camera (ultra ixon 897). but  NI MAX does not detect the camera. of why after you?
(7,429 Views)
Have you installed the NI Vision toolkit/IMAQdx drivers? It is possible that your camera isn't supported, but you should check you have the drivers etc. installed first. You could also contact the manufacturer to see if the camera is supported - maybe they have some LabVIEW examples you can use.
(blog)
(7,414 Views)
Hello there 3 years later. These cameras have a proprietary interface (based on libusb) and are not supported by IMAQ(dx). Coneveniently, they sell an SDK with wrapper dlls and everything and then it should work without IMAQ.
(5,198 Views)
