interactive pull down inputs
I am trying to automated a Wi-Fi board. Some of its inputs (pull down selections, e.g Params Value) are dependent to other inputs ( Combo iw,  e.g iwlist/iwconfig). How to have some inputs values depend on the others before executing the vi interactively. In another words, each iwlist or iwconfig is going to have different pull down menu (case).
Rostam
(3,873 Views)
You can't change your controls dynamically if the VI isn't running.  Your VI should be running (While loop) in order to evaluate changes in your inputs (use User Event Structure in a loop parallel with your main code... or within an Idle state of a state machine).  For each Value Change event which is important, run the appropriate code to change the list items of your other controls (Enums, Rings, Combo Boxes).  After setting all inputs, the user will then click a button to perform your Wi-Fi board tasks.
If you use two loops running in parallel, make sure to properly end both loops when stopping the VI.
(3,868 Views)
You need to use the property node to get to these values. You can use the strings as an input to change the values the show inside of the ring value. So you could set the first ring and have that fill in the other rings based on the first one and so on.
Tim
GHSP
(3,849 Views)
I actually made a VI specifically for updating the items in a combobox.  It also has the capability that if the current value is not a valid one (not in the new list of allowed values) that it will update to the first item and signal the Event Structure to handle it's value changing.  This can be used to cause a chain-reaction to update all of your comboboxes.
(3,841 Views)
Would you share your code with me?  Thanks
Rostam
(3,795 Views)
He did share it with you. The picture that was attached is a snippet. If you save it to your desktop you can drop it into LabVIEW and the code will appear. It is LabVIEW magic.
Tim
GHSP
(3,790 Views)
That snippet was made in LabVIEW 2016, so you will need 2016 or newer in order to use the snippet.
(3,780 Views)
