intensity graph Y axis color ramp control
How can I control the color "curvature" of the intensity ramp? Neither a linear nor log scale work for my data. I am trying to map the color grading of an eye diagram from a scope and can't get the intensity graph to come even close to what the scope displays.
Thanks in advance,
Bob Albern
(5,226 Views)
Hi Bob Albern,
In order to create a smooth color ramp for Intensity charts, you go to your front panel and right-click on the intensity graph/chart color ramp. Make sure that the "interpolate colors" option is checked. Then all you need to do is to specify the "high color" and the "low color" to define the ramp. I also found two great knowledge-base articles that describe how an intensity graph interpolates color and how to change the color on an intensity chart or graph. Also, there are two great examples in the NI Example Finder that would be a great guide: Create IntGraph Color Table.vi and Common Intensity Maps.vi. I hope this helps!
Carla
(5,206 Views)
