intensity chart
Dear sirs/madams,
Is there a quicker way to build a matrix from lining up 1D arrays originating from a For Loop than to use the Replace and Insert functions?
And, which one does one use, chart or graph?
Thank you.
(2,948 Views)
Hi Raff,
I am not sure what you are trying to do here, please can you provide some example code of what you want to do.
I am unsure if you want to combine multiple 1D arrays to make a matrix, or if you are doing something else.
I have attached an example of what I think you want to do, and this should be very quick to run.
Because Matrix data is similar to 2D data, you will need to use a graph and NOT a chart.
Regards
JamesC
NIUK and Ireland
(2,917 Views)
Thank you,
My query's been answered under: "General - concatenate"
(2,913 Views)
