intel hex format
I'm just trying to wrap my head around the fact that he wants to change the compiled code by hand. Egads. I hope that he's changing something innocuous, like a static array of data, or perhaps a fixed portion of flash that's being used as a poor man's EEPROM.
Message 11 of 19
(4,233 Views)
Don't know if it will help you, but I'm attaching a VI I wrote (LabVIEW 2009) for reading an Intel Hex file.  In my application I later downloaded the hex file to a Microchip dsPIC33F microprocessor.  Sorry for the lack of comments.  I wrote this a year ago and haven't touched it since so I don't remember all the details; you might find it shifts the addresses by one bit when displaying the file on screen to match the way the Microchip environment displayed it.  It reads the hex data line by line and builds an array of data chunks, where each chunk has a start address.  This allows it to load a hex file that includes non-contiguous data, but consecutive lines that refer to contiguous memory addresses are combined into a single chunk.
smercurio: I can understand wanting to modify the hex data directly, for example in my application it was easy to have the dsPIC store calibration data in its program memory.
Message 12 of 19
(4,221 Views)
I had to do the same thing on a recent project. The EE who was designing the overall circuit thought the PIC had a separate EEPROM, but it didn't. So, rather than adding another chip at the last minute, we decided to use part of program memory (at an address far away from the actual code) for cal/configuration data. In our case we were only building a couple of prototypes so we did not bother to try to change the hex file to set the default data - we just used the GUI I had written in C# to download the unit-specific cal/configuration data since it was much simpler and more user-friendly. That's why I said I hope that's all the OP is intending to change, as opposed to trying to modify the program code itself.
Message 13 of 19
(4,218 Views)
I have collected all the information from INTEL HEX FILE(like: Address, Record Type, Code) into one Array of cluster
Now I want to write this Array of Cluster into a Text file.
The cluster contains three different fields are as follows:
        Address Field
        Code
        Record Type
Please suggest how can write the above cluster into file Please suggest with some example.
Please see the below attachment
Rahul
Message 14 of 19
(4,190 Views)
Please be more specific, and ideally, write some code first.  How should the text file be formatted?  Are you asking how to write it out as an Intel Hex file, or something else?
Message 15 of 19
(4,176 Views)
has anybody a solution how to calculate intel hex format checksum?
Thank you
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
Message 16 of 19
(3,815 Views)
Hi, I created vi file for convert Intel Hex file to binary file that use for program AVR.
Message 17 of 19
(3,709 Views)
Don't suppose you have a Save Hex File.vi as well?
Message 18 of 19
(2,831 Views)
I had to work with intel hex files recently and I did find that the most convenient way to do this from labview is to do this thru intelhex python library....
It has almost all extra functionality required by me: filling empty space with 0xff, merging two files, selecting ranges, etc
Message 19 of 19
(2,124 Views)
