integration problem
Hi everyone, this is probly an easy question, but I need to know how to intergrate my data. It is for a wireless accelerometer. Ive attached the VI, but I cant seem to get the intergration right. It was built in LV 8.2 with some functions that might not appear for you. The signal output is a single number, orange wire.
(3,737 Views)
Since you are only gettting a single point per iteration, you need to use the ptbypt version.
What determines the loop rate of your while loop?
(3,726 Views)
it is to loop until i tell it to stop
(3,710 Views)
... but how fast?
(3,704 Views)
Im not sure, how do i determine the loop speed?
(3,670 Views)
Since you did not include the subVI, there is no way to tell by looking at the code. How long does it take to read the sensor?
"Determine" is a somewhat fuzzy word in this context:
  • You can measure the loop speed by subtracting successive tick counts using a feedback node.
  • You can define the loop speed by placing a defined wait inside the loop. (e.g. 10ms or 100ms).
Typically, a toplevel user interface loop like this needs a small wait so the loop spins at a defined rate. Without a wait, the program speed will depend significantly on the computer speed and is thus not predictable. If somebody would run in in a few years on a 100x faster computer, it will run 100x faster than today. Without a wait, the program also uses all CPU it can get, slowing donw any other prcesses that need to run once in a while.
(3,641 Views)
