instrument control
Hi Everyone,
I have DSOX3014A Oscilloscope and  33521AQ Function / Arbitrary Waveform GeneratorI installed drivers, devices are connected to computer.When ı open example program and run, program takes first value from devices and devices stop. I can't change freq. or ampl. . I have to restart my devices ?
What should ı do ? What do you suggest me ?
Thank you for your time and attention.
Message 1 of 22
(4,692 Views)
The first thing is don't start a second thread on a problem you are already discussing. Have you followed that advice yet? Have you written any code yet?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 22
(4,680 Views)
the original post where the discussion should be continued is at http://forums.ni.com/t5/LabVIEW/Read-Instrument-Value-and-Saving-Data/m-p/3117876
Message 3 of 22
(4,655 Views)
Sir i watched several tutorials about instrument control. A lesson instructor made a simple program. When i was making same program,this problem happened. I try fixing the problem but i can't ? Also it is not the same problem,this time when i read data from devices(osilloscope, generat) on my computer, devices are not working.
Message 4 of 22
(4,625 Views)
They aren't working how? You just said you can read read the devices.
Message 5 of 22
(4,618 Views)
I run the program and  computer takes data from osilloscope and generator. After that my osilloscope and generator frozen, i can't change freq or amplit... my both devices.
Thank you for your attention.
Message 6 of 22
(4,605 Views)
That is normal and explained in the manuals. The instruments go into remote mode and a light or text 'rem' should show on the instrument panel. Click the Local button on the instrument or issue a GTL (Go To Local) command in the program.
Message 7 of 22
(4,599 Views)
Yes i read the manuals sir. I click the local button but it wasn't working.I can't change device's valuesSmiley Sad
Message 8 of 22
(4,591 Views)
Is the program running? I've never seen an instrument not respond to the local button. Check with the vendor.
Message 9 of 22
(4,584 Views)
Yes sir, program is running when this problem happen.
Message 10 of 22
(4,577 Views)
