instrument assistant error on block diagram
 Hey,
I am facing serious trouble while using Chroma DC power supply.
Since I am not familiar with IVI-C or IVI-COM driver, I decided to use Instrument Assistant I/O.
When I use Instrument Assistant and do the following process in property window:
1. Query and Parse *IDN?
2. Write: SOUR:VOLT 10
3.  Write: CONF:OUTP ON
When I say run in the property window, the following operation takes places and I get required operation. where as when I drop this onto block diagram and say RUN, I get an unknown system error. I would like to know why is this problem happening?
I am using LabVIEW 2009 with latest service pack.
Please revert on this as soon as possible. Thanks.
Sail
(2,375 Views)
IVI-C is a C-based driver that comes in the form of a DLL. IVI-COM is a COM-based driver that comes in the form of an ActiveX interface. More details can be found here. Which driver did you download? This appears to be a continuation of this question.
(2,361 Views)
