installing labVIEW RTE 2010 on labview2013
i have an evaluation license installed for labView2013 and will upgrade to labView full developer suite soon, but I need labView RTE 2010 for an older exe.
How to install labVIEW RTE 2010 on my current NI installs (labview RTE 2012 can not be removed without removing the entire labVIEW software?)
koen.
(3,095 Views)
Accepted by topic author kdCMC
You simply install them in parallel.
If you like to install several LV development environments in parallel, make sure to pick different folders (default when installing).
Norbert
Norbert
Expert: Geometry
(3,091 Views)
You should be able to install RTEs seperately from LabVIEW installs.
Try these links:
2010 RTE 32 bit - http://www.ni.com/download/labview-run-time-engine-2010-sp1/2292/en/
2010 RTE 64 bit - http://www.ni.com/download/labview-run-time-engine-2010-sp1/2293/en/
If someone helped you out, please select their post as the solution and/or give them Kudos!
(3,090 Views)
