01-11-2012 01:33 PM
I have the destination set for the "root system volume/ATS09" for example, but the files are being written directly to the c: drive without a folder
This has worked fine previously. The "check mark" is set on that particular directory in the destinations area of the installer. I don't see why it doesn't work any more.
01-12-2012 01:21 PM
Was the folder created before you tried to install things there?
What operating system are you using?
01-12-2012 08:27 PM
He should not need to create the folder Volume. The installer will create this for him. He would need to create the folder if by another name such as volume/AT90 or whatever.
