installer, library to include
Hello, I am Davide Masi,
I should create an exe file and then also an installer for a real-time applications.
How do I know which libraries to include?
Best Regards
Davide
(2,445 Views)
If you are referring to NI libraries, such as VISA, the installer is usually pretty good at selecting those additional installers to be included with your installer. If you are using custom libraries then you will need to include them yourself. What "libraries" are you using? In the project you can expand the "Dependencies" node to see what's being called.
(2,434 Views)
