installer does not allow for shortcut changes or more than one
I have been trying to create a shortcut for the Start Menu and the Desktop. I can create the two shortcuts except they are exactly setup the same. I try to change one or the other and they both revert back to the original settings. In the attached images you will see that I change the subdirectory to nothing. When I come back to the shortcuts area, the subdirectory is back. If I create a second shortcut, it is the same as the first... I cannot change it.
photo 1: this is how it starts, default
photo 2: My changes... subdirectory is removed
photo 3: I leave the shortcuts area
photo 4: I return to the shortcuts area and the subdirectory is back.
If I create another shortcut, it will act exactly the same. Both shortcuts will be setup as the first photo. No changes stay.
What is going on here?
(2,372 Views)
What LabVIEW version is this?
(2,365 Views)
Once you remove the folder you must hit enter on the keyboard for it to take. Delete the text and hit enter in that box. I had this issue before as well. The real question is: why does labview want to create a folder on the desktop to put the shortcut in? Most all windows applications default to shortcut on desktop. No sub folder.
(2,336 Views)
