installation LV8.6 and 2010
is it possible to install and use LV8.6 und LV2010 on the same workstation
without using different accounts?
Thanks.
Message 1 of 8
(3,359 Views)
I have
  • LabVIEW 7.1
  • LabVIEW 8.2
  • LabVIEW 8.5
  • LabVIEW 8.6
  • LabVIEW 2009
  • LabVIEW 2010
all loaded and running on the same PC without any problems.
I would suggest loading the 8.6 before the 2010.
Omar
Message 2 of 8
(3,335 Views)
My list is not as impressive as the list from Omar. You can install and even in some cases run several Labview versions at the same time. But be very careful not to mix code. You can not mix code between versions. Labview 2010 will be downward compatible with 8.6. But not the other way. It can be mess to clean up in. At least irritating. In labview 2010 you save your code for 8.6. But it is awkward to do this operation.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 3 of 8
(3,328 Views)
Be careful. The version of LabVIEW that opens when you double-click a VI will be the last one that you worked with.  If you don't notice which version starts up and save an old VI.  It will update your file to the new version without ANY warning.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 4 of 8
(3,310 Views)
Coq Rouge is correct, I have more than once "up" converted a VI by mistake.
There is an ini file setting to display the LabVIEW version in the title bar of the VI to help keep thing stright
titlebarRevision=True
Plus I never double click on a VI file to open it but will right click and use the "open with" or set up the "send to" to select which version to use.
Also the file directory structure and project name referances the LabVIEW version the VI are writen in also.
But even with all that I still mess up.
So take warning.
Omar
Message 5 of 8
(3,304 Views)
Thanks for the ini tip Omar.  I can't even use Open with...  Only the last version I had open is in the list.
Message 6 of 8
(3,300 Views)
Accepted by topic author Marco Wolf
just something to add. It depends on your OS. If you use Windows 7, then you can't install the impressive list Omar posted.
Mike
Message 7 of 8
(3,286 Views)
thank you all!
I'll give it a try.
Message 8 of 8
(3,233 Views)
