install error - labview 2009 run-time
I have tried everything in the MS Bullentin with same results.
Let me know if there is anything else that I should try or what the next step is?
Message 11 of 23
(1,524 Views)
Have you tried installing any other software other than National Instruments software? Does that work?
If that doesn't work, we're probably at a point where you will have to reformat your computer and reinstall Windows. This is never a popular choice but it would probably save more troubleshooting time.
Tanya Visser
LabVIEW Group Manager
Message 12 of 23
(1,508 Views)
I did download and install a software that is not NI and this completed just fine.
Any other suggestions?
Message 13 of 23
(1,497 Views)
Have you tried installing any other NI software? If not, try downloading and installing the NI-VISA driver.
Also, what software were you able to successfully install?
Take care!
Tanya Visser
Message 14 of 23
(1,490 Views)
I did try to install the visa program "visa462full.exe" with simiilar error message (see attached error message that popped up).
I was able to install non-NI program "Spybot - Search & Destroy" download link:
http://download.cnet.com/Spybot-Search-amp-Destroy/3000-8022_4-10122137.html?tag=mncol
does this tell you anything?  Do you think my only option is to re-install complete windowsXPsp3?
Message 15 of 23
(1,482 Views)
Are you installing from an administator account, or a user with full privileges?
Tanya Visser
Message 16 of 23
(1,453 Views)
Installing from Administrator account.
Message 17 of 23
(1,446 Views)
Has any NI software ever been installed on this computer before? It may be worthwhile to go to Add/Remove software and look for National Instruments.You could also check your Windows Registry for a National Instrument item. Open the Registy Editor selecting Start»Run... and type regedit. In there look for HKEY_CURRENT_USER»Software»National Instruments. Remove any National Instruments items.
Can you also try installing something like Firefox?
Again, we can spend more time troubleshooting but it could be faster to re-image your computer.
Tanya Visser
Message 18 of 23
(1,426 Views)
I installed Foxfire just fine.
I did clear out an entry for NI software.  I also ran the uninstaller for NI and removed everything.  Then I checked the "programs" folder for any NI folders and deleted one finding.
Last, I re-installed the runtime but still got the same error message.
Would it be any use to send you a copy of my registry?  Please send me your email if that would be a help.
Ben B.
Message 19 of 23
(1,421 Views)
One other thing.... I don't have any NI software installed on the computer.  Only previous attempts at installing the runtime.
Message 20 of 23
(1,420 Views)
