install Labview 8 Error
Dear all,
 I have Labview 7 in my PC, I have not uninstalled it. When I try to install Labview 8, Labview installation shell comes up with an error said that I need to have IE 4.0 or higher. I have IE 7, but my default web browser is Firefox. Is that a matter at all? How should I solve it
thanks
Marco
=Labview 7.0 & 8.0 & 8.5=
(2,624 Views)
Hi zmarcoz
You can find the solution for your problem in the next link:
[broken link removed]
There is a similar case like yours. If you have questions let me  know
Hola zmarcoz
Tu pudes encontrar la solución a tu problema en la siguiente liga:
Ahi se presenta un caso similar como el tuyo. Si tienes alguna pregunta hazmelo saber.
Saludos
También existe el soporte en foros en español si asi lo deseas.
Coamín Cruz
AELATAM
(2,608 Views)
