inserting ring into table
Dear All,
Is there any way to insert Ring into Table ?
 I have a Table whose values are constant but not fixed, e.g, Col 1 can have value 1 or 2.
I have attached the picture of the table to show clearly what i want.
Col "Site" can have values On or OFF.
Col Nerve can have values 1, 2 or 3.
Col Ampl can have values Pk-Pk or Bs-Pk.
Is there any way to make a table such that it can store multiple values for a cell ??
Ritesh
Message 1 of 8
(6,297 Views)
Hmmm.. "constant, but not fixed"...
No, there is no direct way. If you want to display a ring as a selection of a value for a table then you need to code this up yourself. This question has come up many times before. Do a search on this forum and you'll come across several examples.
Message 2 of 8
(6,265 Views)
 Hi smercurio_fc,
Could you please post some links here where this topic has been discussed before .
i tried searching for it, but couldn't get the desired results.
Ritesh
Message 3 of 8
(6,229 Views)
Message 4 of 8
(6,225 Views)
This Vi may help you.
Message 5 of 8
(6,223 Views)
Accepted by topic author LVCoder
Hi Rithesh
  This link will give you the complete detail about your query. If this works let me know.
  http://forums.lavag.org/Table-with-Drop-Down-Items-t11249.html
Message 6 of 8
(6,215 Views)
Hi AutoTEC,
Thanks alot for your Posts.
Yes, it solved my query.:smileyhappy:
I was just going by the Hard way. But now things are alot simpler.
Ritesh
Message 7 of 8
(6,182 Views)
Oh no!  The Lava link is broken.  Any idea on where I can find out how to do this?
Message 8 of 8
(5,736 Views)
