insert string 1d array into 2d array
I'm developing an applycation that requires read a string and look for paterns and matched strings, then convert to 1d array and after insert all that information into a spread sheet I already try using insert into array subvi but what I get it's the original data replaced by the new one,
any help it's welcome
Carlos Ehrenweig
(3,119 Views)
Carlos,
Can you post a VI with the problem? That is usually easier than a verbal description.
Maybe you should try Build Array rather than Insert into Array.
Lynn
(3,110 Views)
You can insert either a new row or new column. I don't know how you could be getting the original array replaced with the new one. Here's a small example that shows how you can insert either a new row or new column. Posting your own VI would make it simpler to understand what is wrong with it.
(3,105 Views)
