insert space character between every character in a string
I have an array of varing length.  Each element in the array contains a string.  I want to put a space character " " between each character of each string in the array.  The length of the string in each element of the array varies.
I have played with nested for loops with shift registers and feedback nodes with no success, and started thinking I'm making this too difficult.
Mike
(8,742 Views)
Try this
(8,735 Views)
Spacer.png  The ASCII code for a space is 32.
- tbob
Inventor of the WORM Global
(8,731 Views)
Hi KSU,
This should do what you are after. No loop is required:
Rgs,
Lucither
"Everything should be made as simple as possible but no simpler"
(8,713 Views)
Accepted by topic author KSU Flyer
(Lucither: Your code will make every other array element an empty string. It does not insert spaces between characters as required.)
There are some nice solutions already posted above, here's another random one. 😉
Message Edited by altenbach on 04-16-2010 11:46 PM
(8,701 Views)
Ah, I see. Misunderstood the question. I thought he had an array of strings and wanted to insert a space in between each string. Sorry Smiley Sad
(8,698 Views)
