insert one single data into excel file
I want to send one single data acquired from DAQ system into a single cell in excel file using Report Generation Toolkit.
(2,639 Views)
You'll need to use the New Report vi and specify Excel as your report type, insert data into the report (remember to specify the cell location), save the report with a specified filename, and finally close the report.
You can find examples for the report generation toolkit in the NI example finder (under Help/Find Examples, and check under catagory toolkits and modules).
Hope this helps,
Dan
(2,639 Views)
