insert into array
I'd like to insert into empty 2-D array element, i don't know indexes and the size of this element. I'd like to insert it at the bottom of the 2-D array. The function "insert into array doesn`t work, how can i do that ?
(3,952 Views)
Use Build Array instead. You will need to right-click on the Build Array function and select Concatentate Inputs
David
(3,942 Views)
Thank you for the solution.
But what should I do if I'd like to insert the elements into the next column ( on the right side of the array)?
(3,932 Views)
Transpose Array, Build Array (Concatenate), Transpose Array
(3,928 Views)
Build array seems fine for this use, but why doesn't Insert Into Array work? And what to do if you would like to arrange a set of 1D arrays into a 2D array, at specific locations? (dependant on an index coming with each array, so the sequence cannot be hardwired)
(3,793 Views)
Insert does not create new elements (or rows or columns) at the end of the array. Often it is better to initialize an array with a value which will never be used by your data (if possible) or a default value which will have minimal impact on the use of the data and then use Replace Array Subset.
Lynn
(3,775 Views)
