insert into array doesn't work
Please see attached screenshot & VI. I want to take a 1D array and break it into a 2-column array. The VI I have written works exactly right the FIRST time I run it. It puts the data in columns 0 and 1. The SECOND time I run it, it places the data into columns 2 and 3. Why does it do this? Since I hardwired the column index to 0, I expect it to OVERWRITE the first run of data and keep putting it into column 0 (and 1).
Message 1 of 21
(7,496 Views)
Hi wb2nvy,
where is your attachment?
Mike
Message 2 of 21
(7,492 Views)
Halarious.  -SS
Message Edited by ShotSimon on 05-21-2008 03:34 PM
Message 3 of 21
(7,490 Views)
I thought I attached jpg and vi but I guess I didn't. Here they are... I hope.
Message 4 of 21
(7,489 Views)
Only 1 attachment stuck. Here's the other one.
Message 5 of 21
(7,486 Views)
Hi wb2nvy,
insert into, means that you insert new data into existing one, so you insert everytime your two arrays into your existing array with start at the first row.
Hope it helps.
Mike
Message 6 of 21
(7,481 Views)
I half understand your answer Mike. I agree it should INSERT into the array the new data, BUT shouldn't it insert it where I TELL IT to insert it, which is starting at COLUMN 0, not ROW 0. I wired the COLUMN index to 0.
Message 7 of 21
(7,472 Views)
The behavior you're seeing is due to the fact that you're using a local variable. The first time you run the VI the indicator is empty. The local variable returns an empty array. You run the VI, now the indicator has values. You run the VI again, now the local variable returns the values that are already there from the previous run.
If you're trying to convert a 1D array to a 2D array, why don't you just use the Reshape Array function?
Message Edited by smercurio_fc on 05-21-2008 03:53 PM
Message 8 of 21
(7,459 Views)
Yes I can use reshape array, but I still want to understand why Insert into array doesn't work. Even if I am using the local variable, I am TELLING the VI to put my data at column 0, regardless of what may already appear there by virtue of the local variable. Should the help file for Insert into array say something like "data will be inserted where you wire the index, UNLESS there's already data there, then all bets are off"?
Message 9 of 21
(7,452 Views)
I don't understand what the confusion is about. Run the VI once, then change your array constant to something else. You will see those new values in columns 0 and 1.
Message 10 of 21
(7,440 Views)
