insert image to SQL database table
Hi ,
i want to know how to insert image in SQL Server database using LabVIEW.
(4,541 Views)
First question: do you know how to insert an image into a SQL Server database *not* using LabVIEW?
Second question: Do you have the LabVIEW database connectivity extension?
Third question: Have you looked at the LabVIEW SQL help?
(4,528 Views)
 this is the Code .
When i  trying to run the vi , I receive this error.
(4,510 Views)
I found this in one old forum, let us know if it helped.
https://forums.ni.com/t5/LabVIEW/ADO-Error-0x80040E57-String-or-Binary-Data-truncated-Error/td-p/126...
regards
(4,473 Views)
Read your JPEG file in as unmodified text (rather than converting to a LabVIEW image format as you are doing) and insert that text.
(4,471 Views)
