insert degrees celcius symbol into front panel text label?
Hi all, i can`t remember the method used to insert a degrees celcius symbol into a front panel text label.  I could simply paste from a previous piece of work but this is really bugging me.  Any ideas?
Message 1 of 20
(14,512 Views)
Grant_Cargill,
i am not sure what you think of by talking of "degree celsius", but i think that you are talking about "°C". this is very simply since "°" is the key on the top left beside the "1"-key (dont forget to hit shift as well 🙂 ).....
Norbert B.
Norbert
Expert: Geometry
Message 2 of 20
(14,505 Views)
Hi Norbert, "¬" is the character located top left on my keyboard when i press shift also?
Message 3 of 20
(14,498 Views)
Grant_Cargill,
well, i believe that you do not use a standard-keyboard for PCs like in the picture i attached. if you cannot find a key with this symbolk (even with shift/alt/alt gr), you can try:
Press ALT and then type (with the numblock) "0186". Hold the ALT-key that long, then release ALT. "°" should appear. This is at least try for Arial and therefore for application-font asuming you are working on Windows-PCs.....
Norbert B.
Message Edited by Norbert B on 08-31-2005 04:36 AM
Norbert
Expert: Geometry
Message 4 of 20
(14,495 Views)
Norbert, my keyboard leyout is different from the attached picture.  However i did manage to create the symbol using the other method invloving the code "0186".  Can you tell me how you discovered that this symbol is represented by this number?
Message 5 of 20
(14,481 Views)
Have just discovered that this "0186" code works on my desktop windows XP PC but not on my windows XP laptop?
Message 6 of 20
(14,477 Views)
Ok, chacracter map has provided the information.  Thanks anyway.
Message 7 of 20
(14,473 Views)
Hi all i tried using the technique like pressing shift with numlock and "0186" even with alt its not working could some one be kind enough to give me an idea as how to insert degree celsius symbol. It would be a great help. Thanks in advance.
Message 8 of 20
(11,884 Views)
Hi Nobert could you please help me with inserting degree celsius on the front panel i tried ur steps and it doesnt seem to help.Thanks in advance
Message 9 of 20
(11,883 Views)
Hi vinod00, have a look in your systems tools/character map and see what keystroke is currently assigned to your degree symbol.
Message 10 of 20
(11,879 Views)
