insert commas ',' between array numbers help!
Hi guys,
I have an array numbers, and i want to have a string format with the numbers separate with commas (,),I want to use this numbers in text. I try to doing but i dont know. i didnt get to add (,)between each number... Can anyone help me?.
I attached a simple example
(3,635 Views)
Here's one way to do it.
You can input any string as seperator (delimiter).
Regards
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,635 Views)
Hi Shoneill, perfect, so it seem very easy ;).
Thank you very much!.
Best regards, Jose.
(3,635 Views)
