insert carriage return into string
can someone tell me how to insert chars like carriage return in to strings in Labview 6.1 ?
(5,546 Views)
Hi FischeFr,
You could use the Replace Substring function in the string pallette with a length of 0 this will then insert the caracter you want at the point in the input string determined by the offset input.
Hope this helps,
Nick
(5,546 Views)
thanks but that didn't answer my question.
Is there a possibility to to add control chars like ,, etc to strings. What I would like to know is if there is a possiblity to mask chars with it's ascii-code or special symbols like "/n" for newline in C and Java
(5,546 Views)
(5,546 Views)
THANKS, PROBLEM SOLVED!
(5,546 Views)
under the string subpallette you will have the ability to use constants for carriages return, tab, etc. Also when on the front panel you can right click on any text indicator or control and select Codes Display. This will allow you to see the /n's. Hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(5,546 Views)
