insert 1d array into 1d array
Hi :
I have two indicators if 1d array
I want to marge between these two array and get in the final 1D array result
array 1
5
6
array 2
7
8
9
I want to get final 1D array result
5
6
7
8
9
can any one help
(3,878 Views)
the build array primitive (fron the array palette) will let you do this, be carefull it can be used to concatenate arrays or to build a 2D array from 2 1D arrays, in your case you want to "concatenate 2 1D array into a 1D array, you can chose the option you want by right clicking on the build array primitive on the front panel and enable/disable the "concatenate" option.
also, you van pull/drag the build array function to increase the number of input (2 in you case).
hope this helps
Epictetus
Antoine Chalons
(3,874 Views)
Accepted by topic author Elyan_wisam
You can use the 'buid array' function.
Wire your two arrays on the 'build array', then right-click on the 'build array' function and select 'concatenate'.
It'll work like a charm !
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(3,872 Views)
Hi Elyam,
next time rethink your wording: You don't want to insert data into an array, but you want to append data to an array!
(3,865 Views)
