initialize value for controller in subVi
When i press the button 'call dialog', the Front Panel of the Dialog.vi will be show. And I wanted the 'New Setpoint' be initialize as the current Setpoint = 2 (or any value for numeric). And i tried writing the value using a local variable during timeout, but it is not possible. the initialization should occur only once in the beginning.
fmpfmpf
(3,304 Views)
here is the attached files
(3,301 Views)
Hi fmpfmpf,
I'm not sure, if this is what you expected, but as attachment, you can find my example...
Hope that helps
Best regards
Dippi
(3,263 Views)
