initialize recursive array - array keeps old values?
Hello together,
i have trouble with using recursive arrays. Running the program the first time works fine, but when I start it a second time the old values in the array are not replaced. They are only replaced, when i have edited the programm code before running the prog. It's very strange...
Here is the prog:
Everytime I run the program the Array should have the size 3 (not 6, 9, ...). How to do this?
The problem might be, that i haven't initialized the array, but how can this be done with recursive used arrays?
An invoke node to reset the output array at the start of the program won't help.
Does anybody have a solution?
Thanks a lot,
 -Peter
Message Edited by FaNan on 07-06-2007 03:09 AM
(3,531 Views)
Hi FaNan,
first:
You should use 'Replace Array Subset' instead of 'Insert into array' - that's the reason why your array grows on and on.
2nd:
I prefer standard shift registers - they better show the dataflow (that's just my opinion).
See attached example in LV71!
(3,518 Views)
Initialize array as shown in the attached file
(3,517 Views)
Hi sowji,
you can't convert a BMP to a JPG just by renaming!
Please attach other picture formats here - your 447kb BMP can be converted e.g to a 10kb PNG...
(3,514 Views)
