initialize linear array
What is the most efficient way to initialize an array of constant increment? I want to quickly build an array with the starting element value, increment, and number of elements all passed in to it. I know I could start with an empty array and keep resizing it and adding element in a for loop. But was told that resizing is not very efficient. Somehow I could use replace array subset. But how do you do that?
Thanks.
(8,454 Views)
Cheers
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(8,448 Views)
Use the VI "Ramp Pattern.vi"
LabVIEW, C'est LabVIEW
(8,445 Views)
Why would you need any "array resizing"? Just use autoindexing. Since N is known from the beginning, LabVIEW can efficiently allocate the output array.
The Ramp pattern that JP mentioned is not available in "LabVIEW base" and the inputs are a bit different than your requirement (N, start, end). It is trivial to cook your own with a few strokes of the mouse. Attached is one example. (LabVIEW 7.0)
Message Edited by altenbach on 05-06-2006 11:10 AM
(8,440 Views)
Thank you all very much! Smiley Happy
(8,398 Views)
thank you for the information but if i need to add upper limit how can you do that
(7,560 Views)
This thread has not seen activity for 8 years, so the information might be a bit stale.
What do you mean by "upper limit"? Do you (1) want a specific endpoint or (2) do you want to coerce the final ramp to an upper limit where it becomes horizontal instead of increasing?
Solution for (1): Have you tried ramp pattern? the "by samples" needs [start, end, N]. "end" is your upper limit?
Solution for (2): add an "In range and coerce" function to the ramp. (words for arrays, limits can still be scalar)
(7,546 Views)
