08-28-2017 01:51 PM
A few properties are Read-Only but generally you right click the property node and choose Change To Write. If this option is greyed out then it is read-only.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
08-28-2017 01:53 PM - edited 08-28-2017 01:55 PM
Some properties are read/write and some are read-only. You can right-click the property and change from read to write if it's allowed for that property. You can also right-click the property node itself and toggle all properties that allow it at once.
EDIT: Must learn to type faster. ![]()
08-28-2017 01:57 PM
08-28-2017 02:40 PM
I appreciate all the ideas and discussion. I will work on designing a solution based on these ideas. Thanks
09-06-2017 11:17 AM
Hello: I created a vi that consists of an LED that is greyed out or is not greyed out, using a property node. This works fine.
I create a sub-vi from this vi and it no longer works. I guess that my property nodes are not referencing the Boolean indicator of the calling VI.
How should this be done correctly?
The indicator vi that works is "indewenable.vi" and the calling program is "tester.vi".
Thanks for your help
Cliff
09-07-2017 04:21 AM
Create a reference to the indicator and pass that into your subVI.
