I am an untrained but somewhat experienced LabView programmer. There, now you know! (Brief Application Description: Two strain gages going to mcu a/d pins. MCU packetizes the 10bit a/d data into a 3rd party message format. This format has 8 data bytes which the mcu shoves a/d data into. This data contains 2 samples of each a/d channel. MCU sends this message to the radio. Radio transmits data to receiver. So the message coming over the air has 4 sets of a/d data that I care about: a/d0 sample0, a/d1 sample0, a/d0 sample1, and a/d1 sample1.)
I am running an event loop based on a callback function of a 3rd party DLL. The message format that comes in has several data bytes that I use (currently 4 data bytes, but I'm likely moving to utilize 8). The data is contained in one data string which I'm trying to extract for use. I need to separate each a/d sample from the data string. Currently I simply average the 2 samples and use that number. However, I need to not average because I need better resolution of the data. So my question is this:
With the event structure running and generating that data each time it fires, how can I extract out each a/d sample? Right now there are 2 samples of each a/d, but I'm likely going to move to 4 samples of each a/d - so does my problem get worse? (you can see the event structure and where I take the mean of both samples for use in the attached vi.)
First time forum user anxious for help! Thanks.
