increment values in array by comparing with an another array
Please find attached
Thanks again
Message 11 of 39
(2,203 Views)
@Rcano_1982 wrote:
Hi Gerdw
thanks for your reply.
I am not able to do what I want with your example. Please see attached my attempt. I do not find a way to store the final count incremented 1 by 1 as per every iteration.
The way to handle arrays in Labview, even the simplest operations really do not get into my brain these days
Any advise?
Thanks a lot
That is nowhere close to GerdW's example.  Look closely at his last example as it is as simple as it will get.
Message 12 of 39
(2,200 Views)
Hi Rcano,
why don't you try my snippets?
Message 13 of 39
(2,194 Views)
Hi GerdW,
Please see attached.
Your snippet does not do what I am trying to do.
Maybe I didnt make myself clear, the result of the comparation must increment(a unit/iteration) only that specific element that matches the value in both Data Array and DataComp.
Message 14 of 39
(2,186 Views)
Hi Rcano,
my snippet does exactly that!
Edit:
Your VI still doesn't look like my snippet.
And it may help to initialize the feedback node. That node is just to show how to store the data. You could use a shift register in your data analysis loop…
Message 15 of 39
(2,182 Views)
Could you check I am using you snippet correctly please?
Please find attached.
Message 16 of 39
(2,187 Views)
That looks correct.
Message 17 of 39
(2,182 Views)
Right,
So do you mean that if put it into a for loop and substitute the feedback node for a shift register, it should work?
No it does not! unless I am missing something else about how to integrate your snippet into my
I have tried with the shift register and it does the same
Message 18 of 39
(2,172 Views)
Message 19 of 39
(2,171 Views)
The screenshot above is how the array looks like after the first iteration.
When it should be (0,0,1,1,0,0)
Am I missing anything?
Message 20 of 39
(2,166 Views)
