increment HOW TO help
The image below should put an end to this silliness.
It is what I explained earlier and similar to what smercurio described.
It's really simple.  So simple, in fact that... anyone ... can do it.
The squares with question marks are most likely your Agilent drivers that I do not have.  You should get the picture...
Message 51 of 52
(626 Views)
@hlod wrote:
 can anyone just change anything, so I can set step size...
NO !!!!!  Nobody can change anything to allow you to set the step size in a For Loop.  It is not possible.  Labview For Loops do not have a step size setting.  It is always a step size of 1.  Period.  It cannot be changed.  End of discussion.
Follow the advice I gave you.  I showed you exactly how to do it.  If you can't follow very simple instructions, I suggest you give up Labview and even engineering in general.  I refuse to help you anymore.  I've helped many people here, and you are the very first person that I ever said that I would refuse to help.
- tbob
Inventor of the WORM Global
Message 52 of 52
(610 Views)
