07-15-2021 06:01 AM
Hello All,
I am trying to change the classic tab color according to RGB settings. the result color is incorrect this can seen both visually and extracting color information using a drawing software.
How can I see the correct color?
Thank!
GIl,
Solved! Go to Solution.
07-15-2021 06:12 AM
Hello GIl,
I just checked in LabVIEW 2018, setting the color interactively or by property node - both times the resulting color is correct.
Can you provide more details: LabVIEW-version, how do you change the color, perhaps upload an example VI with your tab-control.
Regards, Jens
07-15-2021 06:14 AM
Is it just a wrong shade or completely different color?
What is the set color and what is the color you detect with drawing software?
If you can, please share your VI.
07-15-2021 06:29 AM
Are you sure it's a classic tab and not a system tab (or a classic tab customized with parts from a system tab). System controls have various parts that you can't color at all as they take whatever color the system color scheme defines. These parts retain the attribute to use a system color even if you copy them into another control that in itself is not a system control.
07-15-2021 06:59 AM
I'm using labivew 2020.
And I am using the classic tabs.
please see attached VI and screen shots
07-15-2021 07:46 AM
This is NOT a tab control from the classic palette but from the modern (3D) palette.
There you have a small influence of the 3D-highlighting.
Regards, Jens
07-15-2021 07:51 AM
Ok,
This solves the mystery.
I was unaware that there are classic and modern...
Thanks!
Gil,
