incorrect array replacement
Hi I have got a problem regarding the replacement of data in the array.
At first it seems working but the index (0,0) is missing like "V1"
Please advise.
Clement
(2,879 Views)
Your listbox display is scrolled away from default.
One solution: Right-click ... show vertical scrollbar... scroll home ... hide vertical scrollbar. 🙂
(2,877 Views)
Another solution: programmatically set "top left visible cell" to [0,0] via the same property node.
Message Edited by altenbach on 01-31-2008 07:43 PM
(2,876 Views)
It's there. You're just not displaying row 1 of the listbox. Enable the vertical scrollbar and move to the top.
(2,875 Views)
Hi Altenbach and Dennis.
It's weird.
Thanks.
 Clement
(2,863 Views)
