incorporating Microcontroller debugger in Labview
Is it possible for LabVIEW to handle a debugger or programmer of a microcontroller using USB?
I would like the Labview to program the microcontroller using programmer automatically. The programmer can be controlled by USB.
I would also like to know whether LabVIEW can handle softwares used for writing program codes for the microcontroller.
Sail
Message 1 of 20
(6,392 Views)
It is possible, although could be a little difficult. You can use the dll files, to do that.
Another option: Some programmers have exe files, you can call.
No, Labview is a programming language. It can not compile a microcontroler program directly. (if you mean that)
Message 2 of 20
(6,375 Views)
Thanks.
If I can use the case 1. trying to use .exe files of programmer. Will I be able to program the microcontroller after incorporating the programmer into LabVIEW?
Message 3 of 20
(6,362 Views)
Yes.
Which MCU do you use?
Message 4 of 20
(6,347 Views)
I am planning to use PIC microcontroller
Message 5 of 20
(6,328 Views)
Good luck.. I don't know if this, is possible with PIC.
I use Atmel AVR...
Message 6 of 20
(6,318 Views)
Thanks for your help on this and will try out on how to interface PIC's programmer into LabVIEW
Message 7 of 20
(6,308 Views)
Hiya Snail, could I direct you to the following forum post. Hopefully this will give you some further pointers.
http://forums.ni.com/ni/board/message?board.id=170&thread.id=280862&view=by_date_ascending&page=2
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
Message 8 of 20
(6,293 Views)
I was able to use the Microchip PM3 to program a MCU using LabVIEW 7.1. The Microchip IDE included a separate programmer utility called PM3Cmd. I was able to call this program using SystemExec. We had a test system that had to load test firmware into the product for test and then load production firmware afterwards. You just need to have a compatible hex file stored on the hard drive. I know that this application is picky (requires the full memory map, including empty areas). It will show a command window as well, which MUST be the top-most window. If another program has the focus, it takes forever to program the device via USB. It is a quirky program to work with, but it gets the job done.
Message 9 of 20
(6,286 Views)
Dear OlderJohn,
Could you please post that vi. This will help me now and also somebody else later. Thanks a lot in advance.
Mathan
Message 10 of 20
(5,975 Views)
