include documentation with application builder
How do I include a Microsoft Word document.htm with the LABView application builder. I am accessing the document through the help menu in the source code. The menu item displays the Word document with the source code VI but doesn't work when I build it. Thanks!
(3,231 Views)
Try this:
In application builder go to "Source Files".
Add htm file by clicking "add support file".
(3,231 Views)
We're having the same problem. We have the .htm in our source files and it's installed along with the application. The path for Documentation is correct in the VI properties. The "Help for this VI" is available on the Help menu of the application, but nothing happens when it's clicked. We've made sure that the .rtm and .ini files are also included as Support Files. The help .htm is available when running the VI under the development environment (LabView 6.1).
(3,231 Views)
