in place element structure problem
running a project no problem then all of a sudden one of the VI's causes a pause. in place element structure problem flashes red & blue whilst causing a pause to the data capturing? any ideas what this problem maybe?
(2,931 Views)
Accepted by topic author dhanna
You've placed breakpoint on this structure. You can see it by red line inside of the structure border. How to disable it:
- Form menu: select View -> Breakpoint manager, you can clear it from there
alternatively:
- When VI is running, ctrl+click on the structure.
(2,913 Views)
was pretty sure i had removed that one,was looking for the brig red circle sign! thanks
(2,908 Views)
