in calculator significant figure run places
when i key in 2.35, the calculator will show up like 532. . How to change it?
(2,971 Views)
Hello wkling,
Could  you convert your code to LabVIEW 2009 or show some sample snapshot of your code.
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
(2,962 Views)
Swap the inputs to the concatenate strings in the event for the numbers.
(2,942 Views)
Also, you will need to search for "\." and not just "." as the period has a special function and will match any character.  You will never have it equal to 0 when a period/decimal is added.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(272 Views)
