importing a C++ Project
I recieved an Application with code from a vendor. I wanty to import it into the LabviewCVI environment and make it a Labview Project. I have Microsoft Visual C++ 6.0.
I wanted to import it into LabviewCVI so that I can change what I need to and use all Labview  gui's so that everything is in one project file.
Is there a way to do this?
(2,825 Views)
There is no such thing as LabviewCVI. There's LabVIEW, which is a graphical programming environment, and there's CVI (also known as LabWindows/CVI), which is a C-based programming environment. I suspect you want the CVI forum..
Message Edited by smercurio_fc on 06-16-2010 12:59 PM
(2,822 Views)
