import shared library change name function
I used "Import Shared Library" to create lvlib, but it has changed name function, for example on() to Z2onj(), so the created VI doesn't work,
there is this error:
Call Library Function Node 'libname.': Z2onj : Function not found in library
Details:
The function name specified for this node cannot be found in the library. Right-click the Call Library Function node and select Configure, then choose the correct function name.
How can i resolve?
Thanks.
(3,772 Views)
Accepted by topic author nept
Hi Salvo,
you should create again the lvlib with the new name.
Kind regards.
(3,744 Views)
