image to RGB color separation
Hello GerdW,
In that VI you posted, How to edit the Cluster that gives input to Property node. How to add colour and Digits in that cluster input ?
Regards
Neo
Message 21 of 26
(2,005 Views)
Hi Neo,
are you talking about the "Z scale" values? That's an array of cluster and each cluster contains a number and a color (as described in the context help of that property node!).
To edit those values you simply click them with the edit tool (as usual when editing block diagram constants)...
Message 22 of 26
(2,002 Views)
Hello GerdW,
Thank you very much for your quick reply. I have one more question.
From the block diagram data flow , it seems like you have Image data at first and then picture is drawn.  How did you get the image data first ?? where did you extract this data ?
Regards
Neo.
Message 23 of 26
(1,995 Views)
Hi Neo,
did you see message #3 of this thread? The function on the left delivers image data...
Message 24 of 26
(1,992 Views)
Hi GerdW,
Ahhhh... k. Got it. Iam just lost after going through all the posts Smiley Very Happy
THANK YOU
Regards
Neo.
Spoiler
Message 25 of 26
(1,987 Views)
Can you share the example, like how can we do the same using vision library ?
Message 26 of 26
(1,092 Views)
