image processing on matched patterns
Hi all
I am using LabVIEW 7.1 for image processing. I have used the pattern matching example to suit my requirements.
Now i want that whatever image processing operations i perform after pattern matching, like, threshold, circle detection, particle filter etc.. be
performed only on those patterns which have been recognised & not on the entire image. How can this be done?
Thanks all in advance
(2,945 Views)
Hi James,
I suggest you to Extract that image from the main image by using ROI tools,
and thereby the you are left with the cropped image for your analysis.
Use this and paste this on a new blank image for your processing.
Sundar.
(2,940 Views)
