im doing my final year project here and i need help- karasi
I'm trying to make the graph show a temperature from 95 degrees to 55 to 72 and back to 95 degrees and the cycle as follows. With a time cycle of 10 seconds for each temperature change. How do I start with the plotting and the gradual change in the temperature?
Message 41 of 48
(1,449 Views)
I've tried out with the plotting but I'm not sure how to change the temperature from 95 degrees to 55 degrees. I need help in the plotting.
Message 42 of 48
(1,413 Views)
see attached file
Message 43 of 48
(1,382 Views)
I've tried it out but I can't seem to connect the index array though. Could you help me out?
Message 44 of 48
(1,371 Views)
right click on build array>>concatenate inputs
Message 45 of 48
(1,363 Views)
I want to know how do I slow down the graph because it is going too fast. How do I control the time of the graph?
Message 46 of 48
(1,352 Views)
My supervisor asked me to used a counter to do the plotting. That there is supposed to be 3 cases whereby the each plot(from 90 degrees to 55 to 72 degrees) will go through a loop and repeat the plotting again. I need alot of help in this.
Message 47 of 48
(1,330 Views)
Accepted by topic author karnan
I've done the plotting after a LONG time of trying again and again. And I think it works. Here's what I've done.
Message 48 of 48
(1,274 Views)
