ignore ini file line
In an ini file all lines starting with a semi-colon are comments are assumed ignored. The Read Key VI doesn't do this, is there some other symbol used to ignore line in ini files (LV 8.2) or must I remove the colon lines myself...
richjoh
(4,675 Views)
The answers in this thread may help and give some ideas.
(4,664 Views)
Funny thing here since NI Knowledge base claims the semi-colon is used to comment lines using LV 8.0!!!
http://digital.ni.com/public.nsf/allkb/3E417E05832D069B86256F43001AC15B
Obviously this is NOT the case...
richjoh
(4,656 Views)
Specially, maybe NI Knowledge base means semi-colon is used for comment lines "but = sign cannot be included in the line... The knowledge base doesn't include this caveat!!!
richjoh
(4,653 Views)
I know this KB. The LV configuration VIs seem to be the exception !
Anyway, with LV8.5 (I have not tested it with earlier versions) the line will not be considered as a comment even if there is no =.
(4,648 Views)
R&D is currently looking into the use of comments in .ini files.  This was reported to R&D (# 4HDCB9TP) for further investigation.  Thank you both for the feedback.
Jennifer R.
(4,614 Views)
Thank you very much.
(4,595 Views)
