if condition
hi
kindly tell me how can i implement this code in l.v. i do not know how to use if in l.v
here is the code:
for i=1:m
for j=1:n
if b11_mat(i,j)<=lum(i,j)
b11_mat(i,j)=lum(i,j);
end
end
end
thnx
Fairy
Message 1 of 15
(5,989 Views)
Do one thing, Post your C code. I will convert it into LabVIEW.
This is bit confusing.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 15
(5,983 Views)
Hi Fairy,
I think this is basically what you are trying to do with your code.
The case structure is generally a pretty good replacement for the if statement.
You can find a little more about the case structure here.
The other neat thing is the for loop automatically indexes through the arrays for you.
Good Luck,
Brett
Message 3 of 15
(5,977 Views)
Hi fairy,
when all you need is the MAX then you should use the MIN/MAX function:
Obey the POLYMORPHISM! 😄
@Brett:
Using the Select function is more easy to read than a CASE structure in such a simple VI...
Message 4 of 15
(5,952 Views)
I think Gerd has shown you very effective code for your request,
here I just add the possibility to control the value m and n.
regards,
Yan.
Message 5 of 15
(5,931 Views)
Hi Yan,
you don't need FOR loops for that, ArraySubset is sufficient too:
Message 6 of 15
(5,923 Views)
Thnx all of u.. it realy works :).
Message 7 of 15
(5,873 Views)
hi GerdW!
From where i can find max/min vi?
Message 8 of 15
(5,871 Views)
Try the comparison palette.  (Min&Max).
Message 9 of 15
(5,869 Views)
hi!
i have another problem now.
r1= 1 2 3
       4 5 6
r1(:)= 1
          4
          2
          5
          3
          6
how can it possible in l.v?
thnx
Message 10 of 15
(5,860 Views)
