identifying 2 usb barcode scanner
I'm encountering a problem while trying to use 2 usb barcode scanner on the same computer.
Each scanner should handle a different task and is used by different people.
What I would like to is that I get the scanned string directly. Without needing to have the string control active.
I have already seen that in some posts it is suggested tot set the scanner on RS232-mode but since my scanner doesn't support this functions (although I have set it to this no additional com-port is shown in the device manager) this doesn't seem a usable issue.
Thank you very much for any help.
Yves
(2,539 Views)
Hi Yves
You wrote that yu have allready read some other posts. Can you post the link to this posts?
 It would be very helpful if you post a print screen or a smale part of your vi.
(2,504 Views)
