identification usb port
Hi all :
I need help please , I want to bulid  application that if I insert A Device in USB port the application identification this device and give me in the port which was found such as ( 😧 or G: or F: , etc....)
And if this device found give me "true " , if not found give me " false"
Can I do this in labview 8.5 ..
If any one so this before I will be very thankful to know
(3,439 Views)
try
Mathan
(3,437 Views)
I look ,put I don't find any thing that help ,,
i really need this issue to be solved ,, i stuck with it
thanks
(3,433 Views)
(3,412 Views)
Hai elyan,
Do you have that dll you mentioned in your other post? If so attach here. I will try to make it out.
Mathan
(3,411 Views)
(3,392 Views)
Can you rephrase your question? Are you saying that you want to be notified by the operating system when a device is plugged in? What is your operating system?
Also, what do you mean by:
Does this mean that you're doing some sort of initial scan? Please explain in more detail what you're trying to accomplish.
(3,378 Views)
