iImage interpolate
I am using Labview 8.2 and Vision and I need to interpolate some images. Camera takes pictures every second and I need to interpolace some pictures between  that. And I need also to have possibility to change linear, bicubic or other type of intepolation.
Is there any way how to interpolate these pictures?
Thank you very much for your help
Tomas
(2,871 Views)
Hello Tomas,
Thank you for using National Instruments Discussion Forums.  Currently there is not a VI that will interpolate between two images.  You will have to design an algorithm to do that.  We have the ability to resample an image using "IMAQ Resample" that will change the image size and use these interpolation techniques but this VI does not interpolate between two different images.  I hope this information helps.  Thanks and have a great day.
Mark T
(2,856 Views)
