i was unable to establish a serial communication using a DLL library file
i had designed a VI application in Labview7.1, now i had upgraded Labview to 8.5 but my application is not responding. The design includes
Application: I am trying to access a third party controller, through serial communication(RS232 Cable). I am configuring the serial port using a third party DLL library file using call library function block. but i cannot get the starting reciever response.
Message 1 of 9
(3,385 Views)
HI
I think you have not register the dll, use
regsvr32 <dll Path>
Hope this helps
Regards
Santosh
Message 2 of 9
(3,365 Views)
How to do it?
i just tried to register as u said by typing the command at command prmpt, but it is saying the folowing error message
   Module not found
Message 3 of 9
(3,358 Views)
Use following command
regsvr32 "<dll full path>", this command you can use start >run or command prompt
Message 4 of 9
(3,356 Views)
hi santosh,
                    thanks for ur reply, but when i tried to do it as u said at the command prompt i am getting an error message as below
                                           "DLL server point is not available, so the file cant be registered"
Message 5 of 9
(3,344 Views)
Of course it doesn't work. You only register ActiveX dlls and if you had an ActiveX dll you would never had used the Call Library Function Node.
Do you get any error code back from the dll? Do you happen to have open any other serial program such as Hyperterminal or VISA? Is this the same pc that you had your 7.1 application working on?
Message 6 of 9
(3,342 Views)
hi santosh,
                   i cant get u, How do i check whether the dll is activex dll or not. else i do have an activex dll. Mouse, keyboard are USB connected. no other serial communication is connected to it. I am geting 2 errors when i tried to register the file
                     1. DLL server point not found          --    sometimes
                     2. The module was not found        -- sometimes
              One more thing is i am able to get the reciever status for the first time but was unable to connect for the consequtive bit/byte loadings. to the third party controller connected at the other end.
Message 7 of 9
(3,315 Views)
The suggestion to register the dll was wrong. Stop trying.
Message 8 of 9
(3,298 Views)
sir,
        please suggest a method to do it.
Message 9 of 9
(3,281 Views)
